    Are you working from home?
HP Notebook - 15-ra002np Product Specifications
3LF95EA
Intel® Celeron® N3060 (1.6 GHz base frequency, up to 2.48 GHz burst frequency, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 400
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD display
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38 x 25.38 x 2.38 cm
2.1 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 9 hours and 30 minutes
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
