    Fix Windows 10 Update Issues
    Are you working from home?
HP Spectre - 13-af000nx Product Specifications
2VY75EA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB LPDDR3-2133 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 headphone/microphone combo
30.82 x 22.42 x 1.04 cm
1.11 kg
65 W AC power adapter
4-cell, 43.7 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost
HP Audio Switch; HP Cool Control; HP JumpStart
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
