    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion - 17-ab404ur Product Specifications
4HA52EA
Intel® Core™ i5-8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
41.6 x 27.95 x 2.99 cm
3.07 kg
135 W AC power adapter
6-cell, 62 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
FreeDOS 1.2
