    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP ENVY, Spectre Notebook PCs - HP Command Center (Windows 10)
This document is for HP ENVY and Spectre Notebook PCs with HP Command Center and Windows 10.
HP Command Center is a feature in HP ENVY and Spectre Notebook computers that allows you to adjust the temperature and cooling preferences of your notebook by leveraging the hardware, software, and mechanical design of your system to keep you comfortable while using it.
Identifying notebooks with HP Command Center
The following table lists the HP ENVY and Spectre Notebook PC models with HP Command Center.
HP ENVY models
HP Spectre models
HP ENVY 15-cn0000 x360 Convertible PC
HP Spectre x360 - 15-df0000
HP ENVY 15-cp0000 x360 Convertible PC
HP Spectre x360 - 13-ap0000
HP ENVY 13-ag0000 x360 Convertible PC
HP ENVY 17-bw0000 Laptop PC
HP ENVY 13-ah0000 Laptop PC
