    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 14-cm0079au Product Specifications
4RW01PA
AMD A9-9425 Dual-Core (3.1 GHz base frequency, up to 3.7 GHz burst frequency, 1 MB cache)
8 GB DDR4-1866 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ R5 Graphics
  • Integrated
500 GB 5400 rpm SATA
14" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
33.5 x 23.4 x 1.99 cm
Starting at 1.47 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
McAfee LiveSafe™ 30-day free trial offer
