HP Color LaserJet Managed E55040 - 13.B2, 13.B4, 13.B9 jam error in the right door and fuser area
Use the following procedure to check for paper in all possible jam locations inside the right door. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.Az Jam in Right door
  • 13.B2.Dz Jam in Right door
  • 13.B2.FF Jam in Right door
  • 13.B4.FF Jam in Right door
  • 13.B9.Az Fuser jam
  • 13.B9.Bz Fuser jam
  • 13.B9.Cz Fuser wrap jam
  • 13.B9.Dz
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in the right door and fuser area:
The printer model referenced in this video might be different from your printer model, but the steps to clear the jam are the same.
The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
  1. Lift the latch on the right door to release it.
    Figure : Lift the latch to release the right door
  2. Open the right door.
    Figure : Open the right door
  3. Gently pull out any jammed paper from the pick-up area inside the right door.
    Figure : Remove jammed paper from the pick-up area
  4. Close the transfer assembly.
    Figure : Close the transfer assembly
  5. Push down on the green levers to release the jam-access cover.
    Figure : Push the levers down to release the jam-access cover
  6. Gently pull out any jammed paper from the jam-access area. If the paper tears, make sure to remove all remnants.
    Figure : Remove jammed paper from the jam-access area
  7. Close the jam-access cover, and then lower the transfer assembly.
    Figure : Close the jam-access cover
  8. If paper is visible entering the bottom of the fuser, gently pull downward to remove it.
    Do not touch the foam on the transfer roller. Contaminants can affect print quality.
    Figure : Remove jammed paper entering the bottom of the fuser
  9. If paper is jammed as it enters the output bin, gently pull the paper out to remove it.
    Figure : Remove jammed paper entering the output bin
  10. Paper could be jammed inside the fuser where it would not be visible. Grasp the fuser handles, lift up slightly, and then pull straight out to remove the fuser.
    Figure : Remove the fuser
  11. Open the jam-access door. If paper is jammed inside the fuser, gently pull it straight up to remove it. If the paper tears, remove all paper fragments.
    Even if the body of the fuser has cooled, the rollers that are inside could still be hot. Do not touch the fuser rollers until they have cooled.
    Figure : Remove jammed paper from the fuser
  12. Close the jam-access door, and push the fuser completely into the printer until it clicks into place.
    Figure : Reinstall the fuser
  13. Check for jammed paper in the duplex path inside the right door, and remove any jammed paper.
    Figure : Remove jammed paper from the duplex path
  14. Close the right door.
    Figure : Close the right door
