HP Color LaserJet Managed MFP E57540 - 13.A1 tray 1 paper jam
Use the following procedure to check for paper in all possible jam locations related to Tray 1. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. If most of the sheet of paper is visible in the tray, slowly pull the jammed paper out of the printer. Make sure that the entire sheet is removed. If it tears, continue with the following steps to find the remnants.
    If most of the sheet of paper has been pulled inside the printer, continue with the following steps.
    Figure : Remove the jammed paper
  2. Lift the latch on the right door to release it.
    Figure : Release the latch
  3. Open the right door.
    Figure : Open the right door
  4. If jammed paper is present, gently pull it out.
  5. Close the right door.
    Figure : Close the right door
