    Fix HP Printer issue on macOS
HP Web Jetadmin - Low-privilege Service Account
The HPWJA Service and Microsoft SQL Server (HPWJA) service run under the NT AUTHORITY\Network Service account, which is a low-privilege account on the local system. Using this account for both of these services is a critical security feature for HP Web Jetadmin. The NT AUTHORITY\Network Service account must have access to the following locations.
Location
Rights required
C:\Program Files\HP Inc\Web Jetadmin 10
(including all subdirectories and files in the directory structure)
Read & execute, List folder contents, and Read access
Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\HP Inc.\HPWebJetadmin\WjaService
(including all subkeys)
Full control and Read access
Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\WJAUpdateService
This registry key applies only to HP Web Jetadmin 10.2 (10.2.59093) through HP Web Jetadmin 10.4 (10.4.98174). Previous versions do not use this registry key.
Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\HP Inc.\WJAUpdateService
This registry key applies only to HP Web Jetadmin 10.4 SR1 and later. Previous versions do not use this registry key.
Microsoft SQL directory and file structure
C:\Windows\ServiceProfiles\NetworkService
Although you can run both of the HPWJA services under a different account, HP does not provide support to assist with this configuration. Changing the Microsoft Windows account that the HPWJA Service or SQL Server (HPWJA) service runs under might cause unexpected behavior in HP Web Jetadmin or cause both of these services to not start. In this case, HP Web Jetadmin will not run at all.
If you run HP Web Jetadmin under any account other than the NT AUTHORITY\Network Service account, you do so at your own risk.
To verify which account a service is running under, perform the following steps:
  1. Use one of the following methods to open the Microsoft Windows Services window:
    • Start > Programs > Administrative Tools > Services
    • Start > Run > Services.msc
  2. Double-click the service.
  3. On the Properties screen, click the Log On tab.
  4. Verify that the NT AUTHORITY\Network Service account is listed in the This account field.
