    Fix HP Printer issue on macOS
HP Web Jetadmin - Install HP Web Jetadmin from the Command Line
You can install HP Web Jetadmin from a command line, through a script, or through an automated process. The following is the command syntax:
<filename>.exe [/L"<LanguageID>"] [/S /v/qn] </V"[Property1=Value1] [Property2=Value2] [...]">
Command-line parameters
  • <filename>.exe
    Specifies the name of the EXE file that you downloaded from www.hp.com/go/webjetadmin.
  • /L"<LanguageID>"
    Specifies the ID of the language the installer uses (Optional). If the language dialog is enabled and you specify a valid language ID, the installer automatically suppresses the language dialog. If you specify an invalid language ID or a language ID that the installer does not support, the installer ignores this parameter.
    The following are the language IDs. The default is the local system language.
    Language
    Language ID
    Chinese (Simplified)
    2052
    Chinese (Traditional)
    1028
    English (Worldwide)
    1033
    French (European)
    1036
    German
    1031
    Italian
    1040
    Japanese
    1041
    Korean
    1042
    Portuguese (Brazilian)
    1046
    Russian
    1049
    Spanish (Mid-Atlantic)
    1034
  • /S /v/qn
    Performs a silent installation (Optional).
    To perform a silent installation, the following properties are required:
    • WJA_EULA
    • ENABLE_ANONYMIZED_DATA_COLLECTION
  • /V"[Property1=Value1] [Property2=Value2] [...]"
    Specifies a list of properties the installer uses (Required). The following are the properties and values.
    Property and Value
    WJA_EULA=ACCEPT | REJECT
    Specifies whether you accept or reject the HP Web Jetadmin End User License Agreement (EULA).
    This property is required for silent installations.
    ENABLE_ANONYMIZED_DATA_COLLECTION=TRUE | FALSE
    Specifies whether the Data Collection feature is enabled or disabled. This feature collects data about your printers and implementation of HP Web Jetadmin and anonymizes the data. HP Web Jetadmin uses an Internet connection to transmit the anonymized data to HP. HP uses the anonymized data to improve products and services.
    HP is committed to protecting your privacy and the integrity of your computer. You can enable and disable this feature at any time. Your name, address, email address, and other sensitive data are not sent to HP.
    WJA_SKIP_DB_INSTALL=1 | 0
    Specifies whether the database installation is skipped. To skip the database installation, specify 1.
    This property is required only if you want the installer to skip the database installation.
    INSTALLDIR=\"<Path>\"
    Specifies the HP Web Jetadmin installation path. The following is the default path:
    C:\Program Files\HP Inc\Web Jetadmin 10\
    This property is optional for silent installations.
    The path must be enclosed with \". In addition, the properties specified for the /V option must be enclosed with quotes. The following is an example of the correct syntax:
    /V"WJA_EULA=ACCEPT INSTALLDIR=\"C:\Program Files\HP Inc\Web Jetadmin 10\""
    If the path contains spaces and is not enclosed with \", the installer fails.
    DATABASEDIR=\"<Path>\"
    Specifies the database installation path. The following is the default path:
    C:\Program Files\Microsoft SQL Server\
    If the directory name contains spaces, you must use the Windows short-path notation. To find the short-path notation, issue the following command:
    Dir *. /x
    The following are examples of the correct syntax:
    • /V"WJA_EULA=ACCEPT DATABASEDIR=\"C:\SQLServer\""
    • /V"WJA_EULA=ACCEPT DATABASEDIR=\"C:\Program~1\SQLServer\""
Examples of the command-line syntax
The following examples assume that the name of the installation file is WjaSetup-x64.exe.
  • To perform a basic silent installation, enter the following command:
    WjaSetup-x64.exe /S /v/qn /V"WJA_EULA=ACCEPT ENABLE_ANONYMIZED_DATA_COLLECTION=TRUE"
  • To start the installer in Spanish, enter the following command:
    WjaSetup-x64.exe /L"1034"
  • To perform a silent installation with HP Web Jetadmin installed on C:\WJA, enter the following command:
    WjaSetup-x64.exe /S /v/qn /V"WJA_EULA=ACCEPT ENABLE_ANONYMIZED_DATA_COLLECTION=TRUE INSTALLDIR=\"C:\WJA\""
  • To perform a silent installation with HP Web Jetadmin installed on C:\WJA and the database installed on C:\WJADB, enter the following command:
    WjaSetup-x64.exe /S /v/qn /V"WJA_EULA=ACCEPT ENABLE_ANONYMIZED_DATA_COLLECTION=TRUE INSTALLDIR=\"C:\WJA\" DATABASEDIR=\"C:\WJADB\""
  • To perform a silent upgrade, enter the following command:
    WjaSetup-x64.exe /S /v/qn /V"WJA_EULA=ACCEPT ENABLE_ANONYMIZED_DATA_COLLECTION=TRUE INSTALLDIR=\"C:\WJA\" DATABASEDIR=\"C:\WJADB\" WJA_BACKUP_CONFIRM=YES"
