HP LaserJet MFP M72625, M72630 - How to use the hole punch
The hole punch feature is available when an inner finisher hole-punch accessory is installed on the printer. Use the hole punch feature to automatically punch holes in pages during printing, or punch holes in copied sheets. Some hole-punch options also include stapling.
This document contains information about the hole punch options that are available, and how to use the hole punch feature when copying from the ADF, or when printing documents from your computer using the HP print driver.
The number of holes available varies by country/region.
  • For countries/regions that use metric measurements, two or four hole options are available.
  • For countries/regions that use imperial measurements, two or three hole options are available.
  • For Sweden, there are specific hole punch finishers available.
