Document ID: c05971459
Version: 1
Advisory: HP mt20 Mobile Thin Client - Citrix Receiver Version 4.7.0A-1 Is Only Showing on Half of the Laptop Screen When Using Dual Monitor Configuration
Release date : 11-Apr-2018
Last updated : 11-Apr-2018
DESCRIPTION
The Citrix Receiver window only fills half of the mt20 internal display.
This occurs when logging on to the server when using a dual monitor (one external monitor) setup.
This occurs when an external monitor is connected.
SCOPE
Configuration:
  • Citrix Receiver version 4.7.0A-1
  • External monitor is connected
Systems:
  • HP mt20 Mobile Thin Client
  • HP mt20 Mobile Thin Client (ENERGY STAR)
  • HP mt20 Mobile Thin Client series
Operating Systems:
  • Microsoft Windows 10 IoT (Build 1507)
RESOLUTION
Resolve the issue as follows:
  1. Open Settings, System, and then Display.
  2. Under Scale and layout set the scaling to 100%.
Hardware platforms affected : HP mt20 Mobile Thin Client, HP mt20 Mobile Thin Client, HP mt20 Mobile Thin Client (ENERGY STAR)
Support Communication Cross Reference ID : IA05971459
