HP LaserJet MFP M72625dn, HP LaserJet MFP M72630dn - Setting IP address
When you connect your printer to a network, you must first configure the TCP/IP settings for the printer. The settings shown below are the basic settings required for using your printer as a network printer. You can set TCP/IP, DNS server, TCP/IPv6, Ethernet, and IP address allocation methods.
IPv4 configuration
  • If your device does not support a network connection, it will not be able to use this feature (see "Rear view").
  • You can also set the TCP/IPv4 from control panel.
IPv6 configuration
Activating IPv6 from the control panel
Accessing menus may differ from model to model (see "Menu overview").
  1. Press Machine Setup > Network Settings > TCP/IP > TCP/IPv6 from the display screen.
  2. Press the radio button in the display screen to activate the option.
  3. Turn the printer off and turn it on again.
    When you install the printer driver, do not configure both IPv4 and IPv6. We recommend to configure either IPv4 or IPv6.
DHCPv6 address configuration from the control panel
If you have a DHCPv6 server on your network, you can set one of the following options for default dynamic host configuration.
  2. Press DHCPv6 Configuration.
  3. Select the required value you want.
    • Always Enable DHCP: Always use DHCPv6 regardless of router request.
    • Never use DHCP: Never use DHCPv6 regardless of router request.
    • Use DHCP as directed by a router: Use DHCPv6 only when requested by a router.
