    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP 24-f0060 All-in-One Desktop PC Product Specifications
Syrah TS 23.8 in All-in-One chassis
Chassis color might vary depending on your model.
Processor
Intel Core i5-8250U (Kabylake-R)
  • CPU speed: 1.6 GHz, max turbo boost 3.4 GHz
  • CPU cores: 4
  • CPU Cache: 6 MB
  • TDP: 15 W
  • Integrated graphics: Intel UHD Graphics
Memory
Video graphics
Sound/Audio
Networking
CD/DVD disc drive
Memory card reader
Computer case
Power supply
I/O ports
Keyboard, mouse and input devices
This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
