The HP 27fw is a 61 cm (27 in) Display.
Figure : HP 27fw Display
LED feature
Specification
Display size
61 cm (27 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
59.8 x 33.6 cm (23.5 x 13.2 in)
Brightness
300 nits
note: |
Color gamut
72% NTSC
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.311 (H) x 0.311 (V) mm
82 PPI
Inputs
1 VGA
2 HDMI
note: |
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Scan range
VGA
Horizontal: 30 to 80 KHz
Vertical: 50 to 60 Hz
HDMI
Horizontal: 30 to 86 KHz
Vertical: 48 to 75 Hz
Recommended resolution
1920 x 1080 @ 60 Hz (FHD)
note: |
Aspect ratio
16:9
Static contrast ratio
1000:1
Dynamic contrast ratio
10,000,000:1
Response time
5 ms gray-to-gray (GtG) with overdrive
Typical: 14 ms GtG
Maximum: 28 ms GtG
note: |
Power consumption
27 W maximum
Tilt
-5 to +25 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
62.0 x 20.4 x 44.9 cm (24.1 x 8.0 x 17.7 in)
Unpacked: 3.68 Kg (8.11 lbs)
