    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP ENVY x360 - 15-bp170nz Product Specifications
3GB28EA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (4 GB (onboard) and 4 GB (1 x 4 GB))
Video graphics
Intel® UHD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
Dimensions (W x D x H)
35.97 x 24.88 x 1.96 cm
2.04 kg
45 W AC power adapter
3-cell, 55.8 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 10 hours
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
