HP LaserJet Pro MFP M28-M30a Printers - Blinking Lights
This document is for HP LaserJet Pro MFP M28a, M29a, M30a printers.
The following sections describe error conditions with blinking (flashing) lights displayed on the printer control panel, followed by solutions for each error. Find the blinking light pattern that displays on the control panel, and then follow the steps to resolve the issue.
     Example of the control panel buttons, icons, and lights
  1. ID Copy button
  2. Start Copy button
  3. Supply light
  4. Power button and light
  5. Attention light
  6. Cancel button
Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
