Document ID: c05914639
Version: 1
Advisory: HP Remote Graphics Software (RGS) - Windows 10 Version 1709 - Fall Creators Update feature prevents login of second user
Release date : 25-Jan-2018
Last updated : 26-Jan-2018
DESCRIPTION
Windows 10 version 1709 (Fall Creators Update) has a feature to automatically login a user after an update or reboot. An automatic login will prevent a second user from being able to connect. The second user will be seen as a collaborator and can only connect if the logged in user allows access.
SCOPE
Systems:
  • HP Remote Graphics Software (RGS)
Operating Systems:
  • Microsoft Windows 10 Version 1709 (Fall Creator Update)
RESOLUTION
The feature can be disabled by opening up Settings, clicking on Accounts, and then turning off "Use my sign-in info to automatically finish setting up my device after an update or restart".
Hardware platforms affected : HP Remote Graphics Software (RGS), HP Remote Graphics Software (RGS)
Support Communication Cross Reference ID : IA05914639
