The Intel Pro2500 SSD may fail to boot. The SSD cannot be detected and the error 3F0 is displayed. The UEFI diagnostics and SMART Check tests cannot be performed on the drive. The drive may be detected intermittently and the OS may load after several attempts to boot up, however the drive eventually fails to be detected.
The Following errors are displayed:
Figure 1: Boot error: Boot device not found - Hard Disk 3F0
Figure 2: HP Hardware Diagnostics error: No hard drive installed. Please check that the power and data cables are connected properly.
Figure 3: SMART Check error: SMART Check: WARNING - Short DST : NOT AVAILABLE
