HP LD5512 55-inch Large Format Conferencing Display Specifications
Product image
Figure : HP LD5512 55-inch Large Format Conferencing Display
Panel
Specification
Display panel type
ADS
Display size (diagonal)
55.0 inches
Panel bit depth
10-bit (8-bit and 2-bit FRC)
Panel active area (W x H)
1209.6 × 680.4 mm (47.62 x 26.79 in)
Aspect ratio
16:9
Native resolution
3840 × 2160 at 60 Hz
DiplayPort 1.2 or HDMI 2.0 supported.
Viewing angle (typical CR > 10)
Up to 178° horizontal
Up to 178° vertical
Brightness (typical)
350 cd/m2
Contrast ratio (typical)
Static
1,200:1 (typical)
1,000:1 (minimum)
Dynamic
8,000,000:1 (typical)
Dynamic Contrast Ratios during video playback only, depending on series of frames or time duration.
Response time (typical)
8 ms (Gray to Gray)
Pixel pitch (H x V)
315 × 315 um
Default color temperature
Panel native (11500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut
99% sRGB
100% NTSC
Anti-glare
Yes
Special features
Picture-in-Picture (PIP)
Picture-by-Picture (PBP)
User updateable firmware
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu
Minus ("-")
Plus ("+")
Input control
OK/Auto
Power
User-assignable function buttons
20
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Traditional Chinese, and Simplified Chinese)
On-Screen Display (OSD) user controls
Brightness, Color Control, Input Control, Image Control, Audio Control, PIP Control, Power Control, Menu Control, Management, and Information
Signal interface/performance
Specification
Maximum resolution
Recommended resolution
Preset VESA graphic modes/supported resolutions
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
2560 x 1440 at 60 Hz
2560 x 1600 at 60 Hz
3840 x 2160 at 60 Hz
Vertical scan range
24 to 60 Hz
Horizontal scan range
27 to 136 kHz
Pixel clock (maximum)
600 MHz
Video and audio/other inputs
Specification
Connector types
(1) DisplayPort (DP) 1.2
(1) HDMI 2.0
(2) HDMI 1.4
HDCP 1.3 supported for DisplayPort (DP).
HDCP 2.2 supported for HDMI 2.0.
HDCP 1.4 supported for HDMI 1.4.
(1) VGA port
(1) USB 2.0 (service data input only)
Audio
(1) Analog input
(1) Headphone output
Multimedia
(2) 6 W Speakers
Ergonomics
Specification
Plug and play
Yes
VESA mounting
400.0 x 200.0 mm (15.75 x 7.87 in)
Color
Black
Monitor bezel
Power
Specification
Power supply
Internal
Input power
100 to 240 VAC at 50/60 Hz
Maximum power
130 W
Typical power
90 W
Energy aving/standby mode
0.5 W
Power cable length
1.83 m (6.0 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Display Head Dimensions
124.15 x 6.98 x 72.11 cm (48.88 x 2.75 x 28.39 in)
Packaged
138.48 x 17.50 x 82.88 cm (54.52 x 6.89 x 32.63 in)
Unpacked
14.0 kg (30.86 lb)
Packed
19.1 kg (42.11 lb)
What's in the box?
Specification
Monitor and accessories
AC Power cord
DisplayPort (DP) 1.2 cable
HDMI cable
Remote controller
Documentation
Warranty and production notice
Environmental
Specification
Temperature
Operating
0°C to 40°C (32°F to 95°F)
Non-operating
–20°C to 60°C (-4°F to 140°F)
Humidity
Operating
No higher than 80%
Non-operating
0% to 90%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Mercury-free display backlights
Yes
Low halogen
Yes (except cables)
Eco-label certifications & declarations
ENERGY STAR
CE
CB
KC
MSIP
e-standby
Bauart
ErP
MPRII
ICE
TUV
EAC
cTUVus
PSB
ISC
CCC
CEL
CECP
SEPA
GOSTR
SII
ISC
VCCI
FCC
BSMI
SMark
SASO
SABS
Mexico energy
Mexico CoC
PSE
Ctick
BIS
EU REACH
EU RoHS
Voluntary materials restrictions
WEEE
