Samsung SCX-4200 Laser MFP - Loading Paper
This document provides instructions on how to load paper into the paper tray.
The paper input tray can hold a maximum of 250 sheets of 20 lb. (75 g/m2) plain paper.
Loading paper in the paper tray
Use the following steps to load paper into the tray.
  1. Remove the paper tray from the printer.
    Figure : Remove the paper tray
  2. Flex or fan the edge of the paper stack to separate the pages before loading.
    Figure : Flex or fan the paper
  3. Insert the paper stack into the paper tray with the side to be printed on facing down.
    Figure : Load the paper into the tray
    To adjust the paper guides for a different sized paper, go to Changing the size of paper in the paper input tray.
  4. Pay attention to the paper limit mark on both inside walls of the paper tray. Paper overloading may cause paper jams.
    Figure : Paper limit mark
  5. Insert and slide the paper tray back into the printer.
    Figure : Reinstall the tray
    After loading the paper, set up the printer for the paper type and size. The settings made from the printer driver override the settings on the control panel.
To load longer sizes of paper, such as Legal-sized paper, adjust the paper guides to extend the paper input tray.
  1. After pressing and unlatching the guide lock (1), slide the paper length guide out completely to extend the paper tray to its full length (2).
    Figure : Extend the paper tray
  2. After inserting paper into the paper tray, squeeze the front paper length guide and slide it until it lightly touches the end of the paper stack.
    Figure : Adjust the paper length guide
    For paper smaller than letter size, adjust the front paper length guide so that it lightly touches the paper stack.
    Figure : Adjust the front paper length guide
  3. Squeeze the paper width guide, as shown and slide it to the stack of paper until it lightly touches the side of the stack.
    Figure : Adjust the paper width guide
    • Do not push the paper width guides far enough to cause the materials to warp.
    • If you do not adjust the paper width guide, it might cause paper jams.
      Figure : Correct position of the paper guides
Loading paper in the manual feeder
Use the manual feeder to print transparencies, labels, envelopes or postcards in addition to making quick runs of paper types or sizes that are not currently loaded in the paper input tray.
Tips on using the manual feeder:
  • Print materials should be loaded face up with the top edge going into the manual feeder first and placed in the center of the tray.
  • To ensure print quality and to prevent paper jams, only load the specified print media.
  • When printing on 76 x 127 mm (3 x 5 inches) sized media using the manual feeder, open the rear cover when printing.
  • When printing on transparencies, open the rear cover. If not, they may tear while exiting the printer.
Use the instructions for loading paper into the multi-purpose tray.
  1. Load a sheet of the print material with the side to be printed on facing up in the center of the manual feeder.
    Figure : Using the manual feeder
    Depending on the paper type, use the following loading method:
    • Envelopes: load a sheet with the flap side down and with the stamp area on the top left side.
    • Transparencies: load a sheet with the print side up and the top with the adhesive strip entering the printer first.
    • Labels: load a sheet with the print size up and top short edge entering the printer first.
    • Preprinted paper: load a sheet with the design face up, top edge toward the printer.
    • Card: load a sheet with the print side up and the short edge entering the printer first.
  2. Adjust the manual feeder guides to the width of the print material without bending it.
    Figure : Adjust the manual feeder guides
  3. After loading paper, set the paper type and size for the manual feeder.
  4. If necessary, open the rear cover to print special media.
Printing on special media
When printing on special media, consider the following information for each paper type.
