Samsung SCX-4200 Laser MFP - Loading Originals
This document provides instructions on how to load original documents into the printer.
Loading originals on the scanner glass
Using the scanner glass, you can copy or scan originals.
To load an original on the scanner glass, use the following steps.
  1. Open the scanner lid.
    Figure : Open the scanner lid
  2. Place the original face down on the scanner glass and align it with the registration guide at the top left corner of the glass.
    Figure : Align original document with the registration guide
  3. Close the scanner lid. Be careful not to move the document.
    • Leaving the scanner lid open while copying may affect copy quality and toner consumption.
    • Dust on the scanner glass may cause black spots on the printout. Always keep it clean.
    • When copying a page from a book or magazine, lift the scanner lid until the hinges are caught by the stopper and then close the lid. If the book or magazine is thicker than 30 mm, start copying with the lid open.
