Samsung ProXpress SL-C2670 Color Laser MFP - Replacing the Waste Toner Container
This document explains how to replace the waste toner container.
When the life span of the waste toner container has expired, waste toner container-related message appears on the screen display of the control panel, indicating the waste toner container needs to be replaced. Check the waste toner container for your printer.
  • Toner particles can be released inside the printer but it does not mean the printer is damaged. Contact a service representative when print quality problems occur.
  • When you pull out the waste toner container out of the printer, move the container carefully not to drop it from your hands.
  • Make sure that you lay the waste toner container on a flat surface so that the toner does not spill.
Do not tilt or turn over the container.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Turn the power off (1), and then unplug the power cable (2).
    Turn the printer off, then wait a few minutes for the printer to cool.
    Figure : Example of turning the printer off (1), unplug power cable (2)
  2. Open the waste toner container cover.
    Figure : Example of opening the waste toner container cover
  3. Pull the waste toner container out of the printer by pressing on the release as shown.
    Figure : Example of pulling the waste toner container by pressing release (1), and pulling container out
  4. Remove new waste toner container from box, and then carefully insert waste toner container back into the printer.
    Figure : Example of removing the new waste container from box, and then insert back into printer
  5. Take a new waste toner container out of its package.
  6. Replace power cord in printer (1), and then turn the power back on (2).
    Figure : Example of replacing power cord into printer (1), and then turn printer on (2)
