    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP 24f 24-inch Display - Product Specifications
The HP 24f is a 61.0 cm (24 in) Display.
Figure : HP 24f Display
The HP 24f Display
Product numbers
2XN60AA, 3AL28AA
Technical specifications
LED feature
Specification
Display size
61.0 cm (24 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
52.7 x 33.6 cm (20.7 x 11.7 in)
Brightness
300 nits
Color gamut
72%
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.2745 x 0.2745 mm
93 PPI
Inputs
1 VGA
1 HDMI
HDCP supported on HDMI.
Viewing angle
Horizontal viewing angle: 178 degrees
Vertical viewing angle: 178 degrees
Scan range
Horizontal: 30-86 kHz
Vertical: 48-75 Hz
Recommended resolution (H x V)
1920 x 1080 at 60 Hz (FHD)
Full high-definition (FHD) content required to view FHD images.
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
5 ms gray-to-gray (GtG)
Typical: 14 ms GtG
Maximum: 28 ms GtG
Actual performance might vary.
Power consumption
22 Watts maximum
Tilt
-5 to +25 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
54.1 x 18.0 x 40.9 cm (21.3 x 7.1 x 16.1 in)
Unpacked: 2.8 Kg (6.26 lbs)
