The HP 27f is a 68.6 cm (27 in) Display.
Figure : HP 27f Display
LED feature
Specification
Display size
68.6 cm (27 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
59.8 x 33.6 cm (23.5 x 13.2 in)
Brightness
300 nits
Color gamut
72%
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.3114 x 0.3114 mm
82 PPI
Inputs
1 VGA
2 HDMI
note: |
Viewing angle
Horizontal viewing angle: 178 degrees
Vertical viewing angle: 178 degrees
Scan range
Horizontal: 30-86 kHz
Vertical: 48-75 Hz
Recommended resolution (H x V)
1920 x 1080 at 60 Hz (FHD)
note: |
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
5 ms gray-to-gray (GtG)
Typical: 14 ms GtG
Maximum: 28 ms GtG
note: |
Power consumption
27 Watts maximum
Tilt
-5 to +20 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
61.2 x 20.3 x 45.0 cm (24.1 x 8.0 x 17.7 in)
Unpacked: 3.7 Kg (8.11 lbs)
