HP 23f 23-inch Display - Product Specifications
The HP 23f is a 58.4 cm (23.0 in) Display.
Figure : HP 23f Display
The HP 23f Display
Product number(s)
2XN59AA, 3AK97AA
Technical specifications
LED feature
Specification
Display size
58.4 cm (23.0 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
50.9 x 28.6 cm (20.0 x 11.3 in)
Brightness
300 nits
Actual performance might vary.
Color gamut
72% NTSC
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.265 (H) x 0.265 (V) mm
96 PPI
Inputs
1 VGA
1 HDMI
HDCP supported on HDMI.
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Scan range
Horizontal: 30 to 86 KHz
Vertical: 48 to 75 Hz
Recommended resolution
1920 x 1080 @ 60 Hz (FHD)
Full high-definition (FHD) content required to view FHD images.
Aspect ratio
16:9
Static contrast ratio
1000:1
Dynamic contrast ratio
10,000,000:1
Response time
5 ms gray-to-gray (GtG) with overdrive
Typical: 14 ms GtG
Maximum: 28 ms GtG
Power consumption
22 W maximum
Tilt
-5 to +25 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
53.1 x 18.3 x 39.9 cm (20.9 x 7.2 x 15.7 in)
Unpacked: 2.58 Kg (5.69 lbs)
