The following procedures show how to clear paper jams.
- ${title}
- ${title}
hp-hero-support-search
- ${title}
- ${title}
- ${title}
Samsung Xpress SL-C48x Color Laser MFP - Clearing Paper Jams
In tray
To avoid tearing the paper, pull the jammed paper out slowly and gently. Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type.
Remove the cassette tray.Figure : Cassette tray, remove
Remove the jammed paper by gently pulling it straight out.Figure : Paper, remove
Reinstall the cassette tray.Figure : Cassette tray, install
Open the front door.Figure : Front door, open
Close the front door.Figure : Front door, close
Inside the printer
The fuser area is hot. Take care when removing paper from the printer.
Open the rear cover door.Figure : Rear cover door, open
Open the frame-transfer.Figure : Frame-transfer, open
Close the frame-transfer.Figure : Frame-transfer, close
Close the rear cover door.Figure : Rear cover door, close
Make sure the rear cover door clicks in place.Figure : Rear cover door, click
In the exit area
Open the scanner unit.Figure : Scanner unit, open
Close the scanner unit.Figure : Scanner unit, close
- ${title}
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
