Samsung Xpress SL-C460, SL-C462, SL-C463, SL-467 Color Laser MFP - Replacing the Waste Toner Container
This document explains how to replace the waste toner container.
When the life span of the waste toner container has expired, the waste toner container-related message displays on the control panel, indicating the waste toner container needs to be replaced.
  • Toner particles can be released inside the printer but it does not mean the printer is damaged.
  • When you remove the waste toner container from the printer, carefully move the container so as not to drop it.
  • Make sure to place the waste toner container on a flat surface so that the toner does not spill.
  • Do not tilt or turn over the container.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Turn your printer off, unplug the power cord from the back of the printer, and then wait a few minutes for the printer to cool.
  2. Open the front cover.
    Figure : Open the front cover
  3. Remove the toner cartridges.
    Figure : Remove the toner cartridges
  4. Pull the waste toner container out of the printer (1). Remove the cap from the package, and use it to close the waste toner container opening (2). Dispose of the waste toner container (3).
    Figure : Remove the waste toner container
  5. Unpackage the new waste toner container (1). Insert the new container into position (2), then push it to make sure it is firmly seated.
    Figure : Install the replacement waste toner container
  6. Reinstall the toner cartridges.
    Figure : Reinstall the toner cartridges
  7. Close the front cover firmly.
    Figure : Close the front cover
  8. Turn on the printer.
Country: Flag Thailand
