    Windows 11 Upgrade Guide
OMEN X by HP - 17-ap020nr Product Specifications
2LV60UA
Intel® Core™ i7-7820HK (2.9 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1080 (8 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
17.3" diagonal FHD 120 Hz IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Type-C™ Gen 2 Thunderbolt™ 3 (Data up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (Data Transfer Only); 1 Mini DisplayPort™; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
Dimensions (W x D x H)
42.5 x 32.72 x 3.64 cm
4.87 kg
330 W AC power adapter
6-cell, 99 Wh Li-ion
Battery life mixed usage
Up to 5 hours and 30 minutes
Video Playback Battery life
Up to 4 hours and 15 minutes
HP Wide Vision FHD Camera with integrated dual array digital microphone
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant; OMEN Command Center; HP Sure Connect
Pre-installed software
Netflix
