Samsung SCX-6122, SCX-6322 Laser MFP - Replacing the Toner Cartridge
The following procedure shows how to replace the toner cartridge.
When the toner cartridge is completely empty:
  • Toner Empty appears on the display.
  • The printer stops printing. The incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced. Check the type of toner cartridge for the printer.
Users can set the printer to disregard the Toner Empty message and to continue printing.
Replacing the toner cartridge
  1. Pull the release lever to open the side cover.
    Figure : Release lever, pull
  2. Open the front cover.
    Figure : Front cover, open
  3. Turn the cartridge locking lever upwards to release the toner cartridge.
    Figure : Locking lever, upwards
  4. Pull the toner cartridge out.
    Figure : Toner cartridge, remove
  5. Remove the new toner cartridge from its bag.
  6. Thoroughly roll the cartridge five or six times to distribute the toner evenly inside the cartridge.
    Thoroughly roll the cartridge to assure maximum copies per cartridge. Save the box and the plastic bag for shipping.
    If toner gets on any clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
    Do not touch the green underside of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  7. Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
  8. Slide the new toner cartridge in until it locks in place.
  9. Turn the cartridge locking lever downwards until it locks in place.
    Figure : Locking lever, downwards
  10. Close the front cover, then the side cover.
