    Apache Log4j Update
HP LaserJet Pro M14-M17 Printer Series - First Time Printer Setup
This document is for HP LaserJet Pro M15a, M15w, M16a, M17a, and M17w printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, load paper into the input tray, connect the power cable, and then download and install the printer software.
If you are looking for the printer software, go to 123.hp.com/laserjet.
Step 1: Remove the printer from the box, and then remove packing materials
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Open the toner cartridge access door, and then remove the packing tape from inside the printer.
    Removing the packing tape from inside the printer
  3. Remove the toner cartridge.
    Removing the toner cartridge.
  4. Remove the clips from the toner cartridge.
    Removing the toner cartridge clips
  5. Grasp both sides of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    Rocking toner cartridge.
  6. Pull the orange tab to remove the sealing tape from the toner cartridge.
  7. Align the toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
    Insert the toner cartridge.
  8. Close the toner cartridge access door, and then recycle the packing materials.
Step 2: Load plain paper in the input tray
Load plain U.S. letter or A4 paper in the input tray.
  1. Pull down the output tray.
    Pulling down the output tray
  2. Load a stack of U.S. letter or A4 size paper into the input tray with the short edge forward and the print side up. Push the stack into the tray until it stops.
    Loading paper into the input tray.
  3. Slide in the paper guides until they rest against the edges of the paper. Do not push the paper guides so far in that they bind the paper.
    Sliding in the paper guides.
Step 3: Connect the power cord, and then turn on the printer
Plug the printer into a wall outlet, and then turn on the printer.
    Connecting the power cord.
  2. Turn on the printer.
Step 4: Install the printer software
Download the latest version of the printing software from 123.hp.com/laserjet, and then follow the on-screen instructions to install the software.
