    Apache Log4j Update
Samsung SCX-4701, SCX-4725F, SCX-4726FD Laser MFP - Clearing Original Document Jams
This document shows you how to clear an original document paper jam in the printer. When an original document jams in the document feeder, a warning message displays on the control panel.
To avoid tearing the document, remove the jammed document gently and slowly.
To prevent document jams, use the scanner glass for thick, thin, or mixed paper-type originals.
