    Apache Log4j Update
Samsung Laser Printers - Replacing the Waste Toner Container
This document explains how to replace the waste toner container. When the life span of the waste toner container has expired, a waste toner container-related message appears on the control panel screen display, indicating the waste toner container needs to be replaced. Check the waste toner container for the printer, see Available supplies.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Open the front door.
    Figure : CLX-92x1, CLX-93x1 series
    Figure : SCX-812x series
  2. Push the left and right locking levers and push outward as shown in the following. Then remove the waste toner container.
    1. Locking lever
    2. Waste toner container
  3. Remove the new waste toner container from its package.
  4. Insert the new waste toner container until it locks in place.
  5. Close the front door. Make sure that the door is securely closed.
    If the front door is not completely closed, the printer will not operate.
