    Fix Windows 10 Update Issues
    Are you working from home?
Samsung CLX-3170, CLX-3175 Color Laser MFP - Replacing the Waste Toner Container
This document explains how to replace the waste toner container.
When the life span of the waste toner container has expired, the Smart Panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise the printer stops printing.
Replacing the waste toner container
Use these steps to replace the waste toner container.
  1. Turn your printer off, unplug the power cord from the back of the printer, and then wait a few minutes for the printer to cool.
  2. Using the handle, completely open the front cover.
    Figure : Open the front cover
  3. Pull the waste toner container out of the printer using the handle.
    Figure : Remove the waste toner container
    Make sure you lay the waste toner container on a flat surface so the toner does not spill.
  4. Remove the cap from the container as shown, and use it to close the waste toner container openings.
    Figure : Place the cap on the container
    Do not tilt or turn over the container.
  5. Unpackage the new waste toner container.
  6. Insert the new container into position, then push it to make sure it is firmly seated.
    Figure : Install the replacement waste toner container
  7. Close the front cover firmly.
    If the cover is not completely closed, the printer will not operate. Make sure all toner cartridges are installed properly. If a toner cartridge is installed improperly, the front cover will not close.
  8. Turn on the printer.
