Samsung Color Laser Printers - Replacing Toner Cartridges
This document explains how to replace the toner cartridges.
The machine uses four colors and has a different toner cartridge for each one: yellow (Y), magenta (M), cyan (C), and black (K).
The status LED and the toner-related message on the display indicate which individual toner cartridge should be replaced. At this stage, the toner cartridge needs to be replaced. Check the type of toner cartridge for your printer.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Turn the machine off, then wait a few minutes for the machine to cool.
  2. Using the handle, completely open the front cover.
    Figure : Open the front cover
    • Do not touch the green surface, the OPC drum or the front of each toner cartridge, with your hands or any other material. Use the handle on each cartridge to avoid touching this area.
    • Be careful not to scratch the surface of the paper transfer belt.
    • If the user leaves the front cover open for more than a few minutes, the OPC drum can be exposed to light. This will cause damage to the OPC drum. Close the front cover should the installation need to be halted for any reason.
  3. Grasp the handles on the empty toner cartridge and pull to remove the cartridge from the printer.
    Figure : Remove the toner cartridge
    If the user opens the front door, be careful not to touch the underneath of the control panel (the lower part of the fuser unit). The temperature of the fuser unit might be high and could damage skin.
    Figure : Use caution
    When the user opens the front door, and works inside the printer, it is highly recommended to remove the paper transfer belt first. Working could contaminate the paper transfer belt.
  4. Take a new toner cartridge out of the package.
    Figure : Open the replacement toner cartridge
    • Don't use sharp objects, such as a knife or scissors, to open the toner cartridge package. Damage to the surface of the toner cartridge could result.
    • To prevent damage, do not expose the toner cartridge to light for more than a few minutes. Cover it with a piece of paper to protect it if necessary.
  5. Holding both handles on the toner cartridge, thoroughly rock it from side to side to evenly distribute the toner.
    Figure : Rock from side to side
  6. Place the toner cartridge on a flat surface, as shown, and remove the paper covering the toner cartridge by removing the tape.
    Figure : Remove the paper covering
    If toner gets on clothing, wipe it off with a dry cloth and wash it in cold water. Hot water sets toner into fabric.
  7. Make sure the color of the toner cartridge matches the color slot and then grasp the handles on the toner cartridge. Insert the toner cartridge until it clicks into place.
  8. Close the front cover. Make sure the cover is securely latched, and then turn the printer on.
    If the front cover is not completely closed, the printer will not operate.
