    We are upgrading our website
Product Specifications for the HP Ink Tank Wireless 415 Printer (Z4B53A)
Product naming
Model name
Z4B53A
What's included and accessories
What's in the box
HP Ink Tank Wireless 415; HP GT51 Black Ink Bottle (90CC, 5,000 pages); HP GT52 Cyan Ink Bottle (70CC, 8,000 pages); HP GT52 Magenta Ink Bottle (70CC, 8,000 pages); HP GT52 Yellow Ink Bottle (70CC, 8,000 pages); Software CD; Setup poster; Power cord; USB cable.
Connectivity
Ports
6 Hi-Speed USB 2.0
Wireless capability
Yes
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy reduce/enlarge settings
Fit to page
Copy resolution
Up to 600 x 300 dpi
Environmental
Acoustic power emissions
6.0 B(A)
Acoustic pressure emissions
47 dB
Operating humidity range
20 to 80% RH
Non-operating humidity range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30ºC
Recommended operating temperature range (Fahrenheit)
59 to 86ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Environmental specifications
No
Memory
Memory
Integrated
Maximum Memory
Integrated
Mobile printing capability
Mobile printing services
HP ePrint
Networking
Network protocols, supported
9100 Direct IP, LPR, Embedded Web Server, SNMP, SLP, WS-Print
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5 envelopes
Standard input capacity (transparencies)
No
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
76.2 x 127 to 215 x 355 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Photo Inkjet Papers; Matte Inkjet Papers; Glossy Inkjet Papers
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: Up to 200 g/m²; HP 10 x 15 cm photo paper: Up to 300 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
Yes, 210 x 297 mm (A4)
Paper handling - ADF
Automatic document feeder capacity
No
Physical dimensions
Maximum dimensions (W x D x H, metric)
525 x 553.5 x 256.6 mm
Maximum dimensions (W x D x H, U.S. standard)
20.67 x 21.79 x 10.10 in
Weight (metric)
4.67 kg
Weight (U.S. standard)
10.27 lb
Power
Internal
Power supply
Input voltage 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz)
Power consumption
10 watts maximum, 0.07 watts (Off), 2.1 watts (Standby), 0.88 watts (Sleep)
Print cartridges
Number of print cartridges
6 black bottle, set of 3 colour bottles
Replacement cartridges
M0H57AE HP GT51 Black Original Ink Bottle (~5,000 pages); X4E40AE HP GT51XL 135-ml Black Original Ink Bottle (~6,000 pages); M0H54AE HP GT52 Cyan Original Ink Bottle (~8,000 pages); M0H55AE HP GT52 Magenta Original Ink Bottle (~8,000 pages); M0H56AE HP GT52 Yellow Original Ink Bottle (~8,000 pages). Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Duplex printing
Manual (driver support provided)
Print speed black (ISO)
Up to 8 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi
Maximum print area (metric)
216 x 355 mm
Maximum print area (U.S. standard)
8.7 x 13.97 in
Print languages
HP PCL 3 GUI
Regulatory specifications
Electromagnetic compatibility
CISPR 22:2008/EN 55022:2010 Class B; CISPR24:2010/EN 55024:2010; EN 61000-3-2:2006+A1:2009+A2:2009; EN 61000-3-3:2013; ICES-003, Issue 5 Class B; GOST (Russia)
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.6
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum system requirements for Macintosh
Mac OS X v10.12 (Sierra), v10.11 (EI Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Recommended Macintosh system requirements
Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Compatible network operating systems
Windows 10, 8, 7, Vista, XP SP3 or higher (32-bit only), Win Server 2008 R2 and higher (via the command line installer), Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite)
One-year limited hardware warranty
