HP ENVY x360 - 15-bp101no Product Specifications
2VZ48EA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (4 GB (onboard) and 8 GB (1 x 8 GB))
Video graphics
  • NVIDIA® GeForce® MX150 (4 GB GDDR5 dedicated)
  • Discrete
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
Dimensions (W x D x H)
35.97 x 24.88 x 1.96 cm
2.16 kg
90 W AC power adapter
3-cell, 55.8 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
