Document ID: c05805301
Version: 1
Advisory: HP EliteBook X360 1020 G2 Notebook PCs - HP Smart Adapter Message is Displayed Incorrectly When Power Adapter Is Connected
Release date : 17-Oct-2017
Last updated : 18-Oct-2017
DESCRIPTION
The HP Smart Adapter message appears when the power adapter is plugged into a computer in a low battery state (battery level 0-3%). The following message appears when the 65W USB-C power adapter is plugged into the computer:
  • For full performance, connect a higher capacity power adapter.
  • HP recommends using HP power source
Figure : HP Smart Adapter message
SCOPE
Parts:
  • HP 65W USB-C power adapter
Computers:
  • HP EliteBook x360 1020 G2
Operating Systems:
  • Microsoft Windows 10 (32-bit)
  • Microsoft Windows 10 Home (32-bit)
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 Pro (32-bit)
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Anniversary Update (RS1)
  • Microsoft Windows 10 Creators Update (RS2)
RESOLUTION
The HP Smart Adapter message is incorrect. The battery will continue to charge when the power adaptor is plugged in. Ignore this message. HP is investigating this issue.
Hardware platforms affected : HP EliteBook x360 1020 G2 Notebook PC
Support Communication Cross Reference ID : IA05805301
