Product Specifications for the HP Envy Photo 6222 All-in-One Printer (Y0K13D)
Product naming
Model name
HP ENVY Photo 6222 All-in-One Printer
Y0K13D
Connectivity
Ports
1 USB 2.0 client ; 1 Wi-Fi 802.11b/g/n, dual band wifi 2.4/5Ghz, BLE
Wireless capability
Yes, built-in dual band Wi-Fi 802.11b/g/n
Copy
Color copy capability
Yes
Maximum number of copies
Up to 50 copies
Copy speed, black (draft, A4)
Up to 21 cpm
Copy resolution
600 x 600 dpi
Environmental
Acoustic power emissions
6.1 B(A) (print mono, simplex, normal mode at 8ppm)
Acoustic pressure emissions
53 dB(A) (Print mono, simplex , normal mode A4 at 8ppm)
Operating humidity range
20 to 80% RH
Non-Operating humidity range
10 to 90% RH (non condensing)
Recommended operating temperature range (Celsius)
15 to 32ºC
Recommended operating temperature range (Fahrenheit)
59 to 89.6ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Memory
Memory
256 MB DDR3
Mobile printing capability
Mobile printing services
HP ePrint; Apple AirPrint; Mopria-certified; Wireless Direct Printing
Networking
Network protocols, supported
IPv4, IPv6, Bonjour, Custom Raw Port/Port9100, mDNS, Embedded Web Server, Wireless Network Supported,SLP, WS-Print, Wireless b/g/n, WEP/WPA (AES), SNMP, Internet Printing Protocol, Bluetooth LE
Paper handling
Input capacity
Up to 125 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (envelopes)
Up to 5
Standard input capacity (transparencies)
Up to 40 sheets
Standard input capacity (secondary tray)
Up to 15 sheets
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter, Legal, 4 x 5 in, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media sizes, custom (metric)
97.79 x 215 to 127 x 355 mm
Media sizes, custom (U.S. standard)
3.85 x 8.46 to 5 x 13.97 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers, Plain Paper, Light/Recycled
Media weight supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 250 g/m²; HP 10 x 15 cm photo paper: up to 250 g/m²
Media weight supported (U.S. standard)
Tray 1: A4: 21.42 to 25.71 lb; HP envelopes: 21.42 to 25.71 lb; HP Photo Paper: up to 71.42 lb; HP 3.9 x 5.9 in photo paper: up to 71.42 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - ADF
Automatic document feeder capacity
No ADF
Physical dimensions
Maximum dimensions (W x D x H, metric)
453.5 x 502.8 x 193.2 mm
Maximum dimensions (W x D x H, U.S. standard)
17.85 x 19.79 x 7.60 in
Weight (metric)
7.60 kg
Weight (U.S. standard)
16.75 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
13.95 watts (printing), 3.60 watts (ready), 0.93 watts (sleep), 0.20 watts (off)
Print cartridges
Number of print cartridges
2:1 black, 1 Tri-color (cyan, magenta, yellow)
SureSupply note
HP SureSupply alerts you when you should replace a print cartridge and helps you purchase locally or via the Internet. For more information, visit http://www.hp.com/learn/suresupply. Only available with original HP supplies; Internet access required.
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed black (ISO)
Up to 13 ppm
Print speed color (ISO)
Up to 8 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Maximum print area (metric)
209.9 x 349.6 mm
8.26 x 13.6 in
Monthly duty cycle
Up to 1000 pages
Regulatory specifications
Regulatory model number
SNPRC-1701-03
Scan
Scan technology
CIS
Scan resolution, hardware
Up to 1200 dpi
Levels of grayscale
256
Scanning options (ADF)
No ADF
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum ADF scan size (U.S. standard)
8.5 x 14.01 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Microsoft Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows Vista x64 has been removed from support on the CD & Web packs. Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher.
Recommended system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8.Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Minimum System Requirements for Macintosh
OS X v10.10 (Yosemite), v10.11 (El Capitan) , v10.12 (Sierra), 1 GB HD, Internet
Recommended Macintosh system requirements
Mac OS X (Lion), (Mountain Lion), (Mavericks); Intel Core Processor; 1 GB HD; CD-ROM/DVD or Internet; USB
Compatible Network Operating Systems
Windows 10 (32-bit and 64-bit), Windows 8 (32-bit and 64-bit), Windows 7 (32-bit and 64-bit), Windows Vista (32-bit and 64-bit), Windows XP (32-bit) (Professional and Home Editions); Mac OS X v 10.8, v 10.9 or v 10.10; Linux (For more information, see http://hplipopensource.com/hplip-web/index.html).
Operating system (supported note)
One-year limited hardware warranty
