HP EliteDisplay E243 23.8-inch Monitor - Specifications
Panel
Specification
Display panel type
23.8 inches IPS, Micro edge LED backlight
60.45 cm (23.8 in) widescreen
Panel active area (W x H)
52.70 x 29.64 cm (20.75 x 11.67 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal (10:1 minimum contrast ratio)
Up to 178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 cd/m2
Contrast ratio (typical)
Static
1,000:1
Dynamic Contrast Ratio (DCR)
10,000,000:1
Response times
5 ms
Default is 14.0 ms and can be adjusted to as low as 5 ms in the display menu. See user guide for more information.
Pixel pitch
0.2745 mm
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color support
Up to 16.7 million colors (with the use of FRC technology)
Color gamut (typical)
72% (NTSC)
94% sRGB
Surface hardness
3H
Anti-glare panel
Yes
Flicker free
Yes
Low blue light capable
Yes (user selectable in On-screen Display (OSD) menu)
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Plus ("+")/Up/Viewing Mode Menu
Minus ("- ")/Down/Information
Exit/Back/Next Input Port
Power
User-assignable function buttons
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Pixel clock
170 MHz (maximum)
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Video/other inputs/cables
Specification
Connector types
(1) HDMI 1.4
(1) DisplayPort (DP) 1.2
HDCP supported for HDMI and DP.
(1) VGA
USB port
(3) USB 3.0
(2) Downstream and (1) Upstream
Cables
(1) VGA 1.8 m (5.9 ft) cable
(1) DisplayPort 1.8 m (5.9 ft) cable
(1) USB Type-B to Type-A 1.8 m (5.9 ft) cable
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +23° vertical
Swivel range
45°L to 45°R
Pivot rotation
90° (clockwise and counter-clockwise)
Detachable stand
Yes (ships detached)
Height adjustment
150 mm (15 cm)
Cable management
Integrated
Effortless routing of cables through the stand
Color
Silver
Facing bezel, side frame, column stand, and foot
Black
Rear cover and stand center trim
VESA mount
100 mm (3.94 in) with integrated mount
Security lock-ready
Yes
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
38 W
Maximum power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Typical power
21 W
Default power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
Energy saving/standby mode
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (highest setting)
53.87 x 20.50 x 33.30 cm (21.21 x 8.07 x 13.11 in)
Packaged
62.0 x 40.0 x 27.30 cm (24.41 x 15.75 x 10.75 in)
Head only
53.87 x 32.18 x 4.52 cm (21.21 x 12.67 x 1.78 in)
Unpacked
5.59 kg (12.32 lb)
Packaged
8.08 kg (17.81 lb)
Head only
3.08 kg (6.79 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord
Other contents
CD
Documentation
HP Display Assistant (with CD)
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95% (38.7°C maximum wet-bulb)
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Eco-label certifications & declarations
ENERGY STAR
EPEAT Gold (registration varies by country/region)
CEL Grade 2
Microsoft WHQL certification (Windows 7, 8, and 10)
TCO certified edge
SmartWay transport partnership (North American countries/regions only)
CE
CB
MSIP
Mexico COC
ICES
ISO 9241- 307
CU
cTUVus
ISC
CCC
VCCI
FCC
BSMI
WEEE
RCM
ErP
S-mark
