Samsung Laser MultiFunction Printers - Fax setting tips for a Mac driver using SyncThru Web Services
This document is Samsung Laser Printers using SyncThru Web Services for a Mac driver.
For fax settings tips, use the following content:
  • Network PC Fax: Support only Standard/Fine resolution and not support color mode.
  • Smart Fax Diagnostic can be a good way to check the fax line configuration and set up ECM mode/speed.
  • Network PC Fax: not synchronized with pre-fix setting on device and needs to set whole number including pre-fix when it is necessary.
    Figure : Example of not synchronized with pre-fix setting
  • Once the pre-fix is set, then the pre-fix dial will be automatically added when entering the fax number.
    Figure : Example of pre-fix dial automatically added
