HP N240h 23.8-inch Monitor - Specifications
Panel
Specification
Display panel type
23.8 inches, IPS with LED backlight
60.45 cm (23.8 in) widescreen
Panel active area (W x H)
52.70 x 29.64 cm (20.75 x 11.67 in)
Resolution
1920 x 1080 at 60 Hz (Full HD)
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
Brightness
250 cd/m2 (typical)
Static contrast ratio
1,000:1 (typical)
Dynamic contrast ratio
5,000,000:1 (typical)
Response times
5 ms Gray to Gray
Pixel pitch
0.2745 mm
Pixels Per Inch (PPI)
92.55
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color production
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72% (NTSC)
Anti-glare panel
Yes
Flicker free
Yes
Low blue light capable
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Plus ("+")/Up/Next Active Input
Minus ("- ")/Down/Viewing Models Menu
Exit/Back/Information
Power
User-assignable function buttons
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Pixel clock
170 MHz (maximum)
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Video inputs
Specification
Connector types
(1) HDMI (with HDCP support)
(1) VGA (with 1.8 m (5.9 ft) cable)
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +23° vertical
Detachable stand
Yes
Height adjustment
Yes
Color
Black or Silver
Security lock-ready
Yes
Power
Specification
Power supply
External
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
20 W
Typical power
18 W
Sleep power
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (lowest setting)
53.90 x 21.39 x 46.94 cm (21.22 x 8.42 x 18.48 in)
Packaged
61.01 x 20.29 x 42.01 cm (24.02 x 7.99 x 16.54 in)
Head only
53.90 x 4.60 x 32.33 cm (21.22 x 1.81 x 12.73 in)
Unpacked
4.2 kg (9.26 lb)
Packaged
6.4 kg (14.11 lb)
Head only
2.8 kg (6.17 lb)
What's in the box?
Specification
Monitor and accessories
Power cable 1.9 m (6.23 ft)
VGA cable 1.8 m (5.9 ft)
Documentation
CD (includes user guide, warranty, and drivers)
HP Display Assistant (with CD)
HP Display Assistant is a software utility that enables theft deterrence and allows monitor adjustment, color calibration, and security/asset management using the Display Data Channel Command Interface (DDC/CI) protocol of the connected PC or workstation.
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-34° to 60°C (-29.2° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Eco-label certifications & declarations
ENERGY STAR 7.0
EPEAT Gold (registration varies by country/region)
CEL Grade 1
Microsoft WHQL certification (Windows 7, 8, and 10)
TCO certified edge
CEL Grade 1
CB
KCC
CCC
CECP
SEPA
VCCI
BSMI
Australian-New Zealand MEPS
WEEE
