After completing the previous setup steps, download the installation files.
Method 1: Download HP Easy Start (Windows and macOS clients)
Follow the onscreen instructions.
Method 2: Download from product support website
(Windows clients and servers)
Select Software and Drivers.
Download the software for your printer model and
operating system.
Launch the software file from the folder where the file was
saved, and follow the on-screen instructions.
Method 3: IT managed setup (Windows only - clients and servers)
Visit
hp.com/go/upd to download and install the
HP Universal Print Driver.
Do not connect a USB cable now. To use a USB cable to connect the printer to the computer, connect it when prompted during the software installation.
Figure : Do not connect a USB cable yet
The default driver for macOS is the Apple AirPrint driver. To install the full featured HP driver, in the Add dialog, select the HP driver from the Use: drop-down list.
For software installation instructions, select the operating system from the options below, and then click the link for the type of connection.
