Samsung MultiXpress MFP SL-K4250-K4350, Color MFP SL-X4220-X4300 - Printer Specifications
Hardware specifications
Item
K425x series
K430x, K435x series
X422x series
X425x, X430x series
Dimension
Height (with Duplex Automatic Document Feeder)
829 mm (32.6 inches)
879 mm (35.3 inches)
Depth
640 mm (25.2 inches)
Width
566 mm (22.3 inches)
Printer without consumables and options
62 Kg (136.6 lbs.)
63 Kg (138.9 lbs.)
80 Kg (176.4 lbs.)
80 Kg (176.4 lbs.)
Environmental specifications
Item
K425x series
K430x series
K435x series
X422x series
X425x series
X430x series
Noise Levela, b
Ready mode
30 dB(A)
Printing mode (Simplex) (Duplex: Simplex+2dBA)
Tray 1: 50dB(A)
Tray 1: 51dB(A)
Tray 1: 52dB(A)
Tray 1: 48dB(A)
Tray 1: 49dB(A)
Tray 1: 50dB(A)
MP: 52dB(A)
MP: 53dB(A)
MP: 54 dB(A)
MP: 50 dB(A)
MP: 51dB(A)
MP: 52 dB(A)
Option tray: 52dB(A)
Option tray: 53dB(A)
Option tray: 54dB(A)
Option tray: 50dB(A)
Option tray: 51dB(A)
Copying mode (Simplex) (Duplex: Simplex+2dBA)
Tray 1: 53dB(A)
Tray 1: 55dB(A)
Tray 1: 55dB(A)
Tray 1: 53dB(A)
Tray 1: 54dB(A)
Tray 1: 54dB(A)
MP: 55 dB(A)
MP: 57 dB(A)
MP: 57 dB(A)
MP: 55 dB(A)
MP: 56dB(A)
MP: 56dB(A)
Option tray: 55dB(A)
Option tray: 57dB(A)
Option tray: 56dB(A)
Temperature
Operation
10 to 32°C (50 to 90°F)
Storage
-20 to 40 °C (-4 to 104 °F)
Humidity
Operation
20 to 80% RH
Storage
10 to 90% RH
a. Sound Pressure Level, ISO 7779. Configuration tested: printer basic installation, A4 paper, simplex printing.
b. China only: If the equipment's noise is louder than 63 dB (A), the equipment should be placed in a country/region of relatively independent advice.
Electrical specifications
Power requirements are based on the country/region where the device is sold. Do not convert operating voltages. Doing so might damage the device and void the product warranty.
Item
Power ratinga
110 volt models
AC 110 - 127 V
220 volt models
AC 220 - 240 V
Power consumptionb
Average operating mode
Less than 1,200 W
Ready mode
Less than 250 W
Power save mode
Less than 1.5 W
Power off mode
Less than 0 W
a. See the rating label on the printer for the correct voltage, frequency (hertz), and type of current for the printer.
b. The power consumption might be affected by the printer’s status, setting conditions, operating environment, and measuring equipment and method the country/region uses.
Print paper specifications
Type
Size
Dimensions
Print paper weight/Capacity (Simplex)a
Tray 1,2,3,4
Multipurpose Tray
Plain paper
Letter
216 x 279 mm (8.5 x 11 inches)
70 to 90 g/m2 (19 to 24 lb. bond)
520 sheets of 80g/m2 (20 lb. bond) for each tray
A3, Ledger and 8K are not supported in Tray 1.
100 sheets of 80 g/m2 (20 lb. bond)
Ledger
279 x 432 mm (11 x 17 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.25 x 10.5 inches)
Statement
140 x 216 mm (5.5 x 8.5 inches)
A3
297 x 420 mm (11.7 x 16.5 inches)
A4
210 x 297 mm (8.27 x 11.7 inches)
A5
148 x 210 mm (5.85 x 8.27 inches)
B4
257 x 364 mm (10.1 x 14.3 inches)
JIS B5
182 x 257 mm (7.16 x 10.11 inches)
ISO B5
176 x 250 mm (6.93 x 9.84 inches)
US Folio
216 x 330 mm (8.5 x 13 inches)
Oficio
216 x 343 mm (8.5 x 13.5 inches)
8K
270 x 390 mm (10.75 x 15.5 inches)
16K
195 x 270 mm (7.76 x 10.75 inches)
A6
105 x 148 mm (4.13 x 5.82 inches)
Not available in Tray 1,2,3,4
Envelope
Letter, A4
Refer to the Plain paper section
75 to 90 g/m2 (20 to 24 lb. bond)
10 sheets stacking
Envelope Monarch
98 x 191 mm (3.87 x 7.5 inches)
Envelope No. 10
105 x 241 mm (4.12 x 9.5 inches)
Envelope No. 9
98 x 225 mm (3.87 x 8.87 inches)
Envelope DL
110 x 220 mm (4.33 x 8.66 inches)
Envelope C5
162 x 229 mm (6.37 x 9.01 inches)
Envelope C6
114 x 162 mm (4.48 x 6.38 inches)
Envelope C4
229 x 324 mm (9.01 x 12.75 inches)
Thick paper
91 to 105 g/m2 (25 to 28 lb. bond)
400 sheets for each tray
50 sheets stacking
Heavy weight paper
106 to 176 g/m2 (29 to 47 lb. bond)
350 sheets stacking
20 sheets stacking
Extra heavy weight
177 to 220 g/m2 (47 to 59 lb. bond)
Not available in the MP Tray
200 sheets stacking
Thin paper
60 to 69 g/m2 (16 to 18 lb. bond)
520 sheets stacking
100 sheets stacking
Cotton
400 sheets stacking
50 sheets stacking
Colored/Preprinted
400 sheets stacking
50 sheets stacking
Recycled
60 to 90 g/m2 (16 to 24 lb. bond)
400 sheets stacking
100 sheets stacking
Bond
105 to 120g/m2 (28 to 32 lb. bond)
350 sheets stacking
20 sheets stacking
Archive
N/A
N/A
Letter head/Hole punched
400 sheets stacking
50 sheets stacking
Thin cardstock/Thin glossy
106 to 163 g/m2 (28 to 43 lb. bond)
350 sheets stacking
20 sheets stacking
Labelsb
Letter, A4
120 to 150 g/m2 (32 to 40 lb. bond)
20 sheets stacking
Tray 1 minimum size (custom)
60 to 220 g/m2 (16 to 59 lb. bond)
N/A
Tray 1 maximum size (custom)
297 x 364 mm (11.7 x 14.3 inches)
Tray 2, 3, 4 minimum size (custom)
Tray 2, 3, 4 maximum size (custom)
297 x 432 mm (11.7 x 17 inches)
Multipurpose Tray minimum size (custom)
98 x 148 mm (3.87 x 5.82 inches)
N/A
60 to 176 g/m2 (16 to 47 lb. bond)
Multipurpose Tray maximum size (custom)
297 x 432 mm (11.7x 17inches)
a. Maximum capacity might differ depending on paper weight, thickness, and environmental conditions.
b. The smoothness of the labels used in this printer is 100 to 250 (Sheffield). This means the numeric level of smoothness.
System requirements
Microsoft® Windows®
Requirement (Recommended)
CPU
RAM
Free HDD space
Windows® XP Service Pack 3
Intel® Pentium® III 1 GHz (Pentium IV 2 GHz)
512 MB (1 GB)
1.5 GB
Windows Server® 2003
512 MB (1 GB)
1.5 GB
Windows Server® 2008
Intel® Pentium® IV 1 GHz (Pentium IV 2 GHz)
512 MB (2 GB)
10 GB
Windows Vista®
Intel® Pentium® IV 3 GHz
512 MB (1 GB)
15 GB
Windows® 7
Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher
1 GB (2 GB)
16 GB
Support for DirectX® 9 graphics with 128 MB memory (to enable the Aero theme).
DVD-R/W Drive
Windows Server® 2008 R2
Intel® Pentium® IV 1.4 GHz (x64) processors (2 GHz or faster)
512 MB (2 GB)
10 GB
Windows® 8
Windows® 8.1
Windows® 10
Windows® Server 2016
2 GB (2 GB)
20 GB
DVD-R/W Drive
Windows Server® 2012
Windows Server® 2012 R2
512 MB (2 GB)
32 GB
  • Internet Explorer 6.0 or higher is the minimum requirement for all Windows operating systems.
  • Users who have administrator rights can install the software.
  • Windows Terminal Services is compatible with the printer.
Mac
CPU
RAM
Free HDD space
Mac OS X 10.5
Intel® processors
512 MB (1 GB)
1 GB
867 MHz or faster Power PC G4/G5
Mac OS X 10.6
Intel® processors
1 GB (2 GB)
1 GB
Mac OS X 10.7-10.10
Intel® processors
2 GB
4 GB
Linux
Items
Requirements
Red Hat Enterprise Linux 5, 6
Fedora 13, 14, 15, 16, 17, 18, 19
OpenSUSE 11.3, 11.4, 12.1, 12.2, 12.3
Ubuntu 10.04, 10.10, 11.04, 11.10, 12.04, 12.10, 13.04
SUSE Linux Enterprise Desktop 10, 11
Debian 5.0, 6.0, 7.0, 7.1
Mint 13, 14, 15
CPU
Pentium IV 2.4 GHz (Intel Core™ 2)
RAM
512 MB (1 GB)
Free HDD space
1 GB (2 GB)
Unix
Items
Requirements
Sun Solaris 9, 10, 11 (x86, SPARC)
HP-UX 11.0, 11i v1, 11i v2, 11i v3 (PA-RISC, Itanium)
IBM AIX 5.1, 5.2, 5.3, 5.4, 6.1, 7.1 (PowerPC)
Free HDD space
Up to 100 MB
Network environment
Network and wireless models only, see Features by model.
Users need to set up the network protocols on the printer to use it as the network printer. The following table shows the network environments supported by the printer.
Items
Ethernet 10/100/100 Base-TX Wired Lan
Network operating system
Windows® XP, Windows Server® 2003, Windows Vista®, Windows® 7, Windows® 8, Windows Server® 2008 R2
Various Linux OS
Mac OS X 10.5 - 10.10
UNIX OS
Network protocols
TCP/IPv4
DHCP, BOOTP
DNS, WINS, Bonjour, SLP, UPnP
Standard TCP/IP Printing (RAW), LPR, IPP, WSD, AirPrint, Google Cloud Print
SNMPv 1/2/3, HTTP, IPSec
TCP/IPv6 (DHCP, DNS, RAW, LPR, SNMPv 1/2/3, HTTP, IPSec)
