Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280 - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge.
When the toner cartridge is totally empty:
  • The status LED turns orange on and the display screen shows the error message of replacing toner.
  • The printer stops printing and incoming faxes are saved in memory. However, when the color toner cartridges are empty, but there is toner in the black toner cartridge, you can still print black-and-white print jobs (the submitted job must be in black and white).
  • Check the type of the toner cartridge for your printer.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Open the front door.
    Figure : Open the front door
  2. Disconnect the used toner cartridge (1) and remove it from the printer (2).
    Figure : Remove the used toner cartridge
  3. Remove the new toner cartridge from the packaging.
    Figure : Unpackage the new toner cartridge
  4. K325x/ K330x series only: Carefully pull the sealing tape out of the toner cartridge.
    Figure : Remove the sealing tape
  5. Gently rock the toner cartridge back and forth to distribute the toner.
    Figure : Gently rock the toner cartridge
  6. Gently insert the new toner cartridge into the printer (1) and secure it in place (2).
    Figure : Insert the new toner cartridge
  7. Close the front door.
    Figure : Close the front door
