Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280 - Changing the Scan Feature Settings
This document explains how to adjust the document settings for each scan job, such as resolution, duplex, original size, original type, color mode, darkness, and more. The settings you change are maintained for a certain time, but after that period, the options are reset to default values.
Changing the scan feature settings
Use these steps to change the menu options.
Some menus may not appear in the display depending on options or models.
  1. Press the Scan menu on the display screen.
    Figure : Ready to Copy screen
  2. Place the originals face up in the RADF or place a single original face down on the scanner glass and close the RADF.
  3. Press the Basic , Advanced, Image, or Output tab on the display screen to customize scan settings including reduce/enlarge, darkness, original type, and more.
  4. Press the appropriate option to set the scan settings, as described in the table.
Item
Original Size
Sets the image size.
Original Orientation
  • Upright Images: Select this setting for an original document loaded with the top toward the back of the printer.
  • Sideways Images: Select this setting for an original document loaded into the RADF with the top of the original document toward the left side of the printer or an original document placed on the scanner glass with the top of the original document toward the right side of the printer.
Original Type
The original type setting is used to improve the scan quality by selecting the document type for the current scanning job.
  • Text: Use for originals containing mostly text.
  • Text/Photo: Use for originals with mixed text and photographs.
  • Photo: Use when originals are photographs.
Resolution
You can adjust document resolution.
Press the resolution and choose the values. The higher value you select, the clearer the result, but the scanning time may take longer.
Color Mode
You can select the color options of scan outputs.
  • Color: Uses color to display an image: 24 bits per pixel, 8 bits for each RGB, is used for 1 pixel.
  • Gray: Uses the black gradation to display an image: 8 bits per pixel.
  • Mono: Displays an image in black and white. 1 bit per pixel.
Duplex
  • 1 Sided: For originals that are scanned on one side only.
  • 2 Sided, Book: For originals that are scanned on both sides.
  • 2 Sided, Calendar: For originals that are scanned on both sides, but the back is rotated 180 degrees.
If an original is placed on the scanner glass, the printer shows the window asking to place another page. Load another original and press Yes. When you finish, select No for this option.
Darkness
Adjusts the brightness level to scan.
Filing Policy
This option is available when USB memory is inserted into the USB memory port on your printer.
You can choose the policy for generating file names before you proceed with the scan job through the USB memory device. If the USB memory device already has the same name entered, you can rename or overwrite it.
  • Change Name: If the USB memory device already has the same name when you enter a new file name, the file will be saved as a different file name that is automatically generated.
  • Cancel: Does not send the scanned file if a file with the same name is already on the server.
  • Overwrite: The sent file overwrites the existing file.
File Format
  • JPEG: Scans originals in JPEG format.
  • PDF: Scans originals in PDF format. You can open the file with the Adobe Acrobat Reader.
    • Page Settings: Determines whether to save the scanned originals into one or multiple files.
      • Multi Page: Saves originals in one file. If you want several originals scanned as one file, press Multi Page.
      • Page Separation: Separates the scanned originals into multiple files that include the specified number of pages. This feature is available only if the Multi Page option is enabled.
    • Searchable: The printer detects text in the scanned image and creates a searchable PDF for text searching. Press this button and select a language that is used in the scanned image. Press OK.
    • Compact: To compress originals to create a small-sized file, press Compact. This compression method is different from the normal PDF format. Some data parts can be lost during compression.
    • Add Digital Signature: You can insert a digital signature in the PDF with a certificate.
      Only an administrator can manage the digital certificate on Digital Signature in PDF from SyncThru™ Web Service.
    • PDF Encryption: Encrypts PDF files.
  • TIFF: Scans originals in TIFF (Tagged Image File Format).
  • XPS: Scans originals in XPS (XML Paper Specification).
Adjust Background
Adjust the background to some extent by adjusting density or brightness. You can lighten, or delete the dark background of colored paper or newspaper to be scanned.
When you use this option, Erase Backside Image in the Image tab is inactivated.
  • Off: Disables this feature.
  • Auto: Automatically adjusts background brightness.
  • Enhance: Darkens the background. Use the left/ right arrows to toggle the values.
  • Erase: Lightens the background. Use the left/right arrows to toggle the values.
This feature prevents scanning the other side’s image if it is showing through the original paper.
  • Off: Turns this option off.
Quality
You can use this option to produce a high-quality document. The higher quality you select, the larger file size you get.
  • Best: Produces a high-quality image, but the file size will be larger.
  • Normal: Both the image quality and file size will be between Best and Draft.
  • Draft: Produces a low-quality image, but the file size will be smaller.
Scan to Edge
Scans the document all the way to the edge of the paper.
Build Job
After the scanning is finished, the Scan More Pages window appears to ask if you want to scan another page. If you select Yes, then you can scan another page in the current job. If you select No, then the scanning process is completed and the remainder of the job is performed.
