    We are upgrading our website
Samsung Xpress MFP SL-M2070, SL-M2071 - Scanning and Sending Via SMB/FTP
This document explains how to scan and send via SMB/FTP. It describes how to set up an SMB/FTP server and then scan and send to an SMB/FTP server.
This feature may not be available depending on model or optional goods.
Setting up an SMB/FTP server
Use these steps to set up an SMB/FTP server.
  1. Access the SyncThru™ Web Service.
  2. Click Address Book, Individual, then Add.
  3. Check the box next to Add FTP or Add SMB.
  4. Enter the IP address in dotted decimal notation or as a host name.
  5. Enter the server port number, from 1 to 65535.
  6. Check the box next to Anonymous, then the server permits the access of unauthorized people.
  7. Enter the login name and password.
  8. Enter the domain name if your server is joined to the certain domain, otherwise just enter your computer name which is registered to the SMB server.
  9. Enter the path for saving the scanned image.
    • The folder to save the scanned image in must be on the root.
    • The folder properties must be set up as shared.
    • Your user name should have the rights to read and write the folder.
  10. Click Apply.
Scanning and sending to an SMB/FTP server
Use these steps to scan and send to an SMB/FTP server.
  1. Make sure that your machine is connected to a network.
  2. Place a single document face down on the document glass, or load the documents face up into the document feeder.
  3. Press Scan, then Scan to SMB or Scan to FTP.
    On some models, press Scan, then SMB or FTP.
  4. Select a server and scan format you want.
  5. The printer begins scanning and then sends the scanned image to the specified server.
