Samsung Xpress MFP SL-M2070, SL-M2071, SL-M2885 - Basic Copying
Basic copy
  1. Select (Copy) > (Menu) > Copy Feature on the control panel, or select (Menu) > Copy Feature on the control panel.
  2. Place a single document, see Loading originals.
    Figure : Copier
  3. To customize the copy settings including Reduce/Enlarge, Darkness, Original and more by using the control panel buttons, see Changing the settings for each copy.
  4. If necessary, enter the number of copies using the arrow or number keypad.
  5. Press (Start).
To cancel the copying job during the operation, press the (Stop/Clear) button and the copying will stop.
The printer provides default settings for copying so that users can quickly and easily make a copy. However, if users want to change the options for each copy, use the copy function buttons on the control panel.
  • If users press the (Stop/Clear) while setting the copy options, all the options set for the current copy job will be canceled and returned to their default status. Or, they will automatically return to their default status after the print completes the copy in progress.
  • Accessing menus might differ from model to model, see Accessing the menus.
  • It might be necessary to press OK to navigate to lower-level menus for some models.
Darkness
If there is an original containing faint marking and dark images, users can adjust the brightness to make a copy that is easier to read.
  1. Select (Copy) > (Menu) > Copy Feature > Darkness on the control panel, or select Darkness on the control panel.
  2. Select the appropriate option and press OK. For example, Light +5 would be the lightest, and Dark +5 would be the darkest.
  3. Press the (Stop/Clear) button to return to ready mode.
Original
The original setting is used to improve the copy quality by selecting the document for the current copy job.
  1. Select (Copy) > (Menu) > Copy Feature > Original Type on the control panel, or select (Menu) > Copy Feature > Original Type on the control panel.
    • Text: Use for originals containing mostly text.
    • Text/Photo: Use for originals with mixed text and photographs.
      If texts in the printout is blurry, select Text to get the clear texts.
    • Photo: Use when the originals are photographs.
    • Map: Use when the originals are map.
Reduced or enlarged copy
Users can reduce or enlarge the size of a copied image from 25% to 400% from the document feeder or scanner glass.
  • This feature might not be available depending on model or optional goods, see Variety feature.
  • If the printer is set to Eco mode, reduce and enlarge features are not available.
To select from the predefined copy sizes
  1. Select (Copy) > (Menu) > Copy Feature > Reduce/Enlarge on the control panel, or select (Menu) > Copy Feature > Reduce/Enlarge on the control panel.
  2. Select the appropriate option and touch OK.
To scale the copy by directly entering the scale rate
  1. Select (Copy) > (Menu) > Copy Feature > Reduce/Enlarge > Custom on the control panel, or select (Menu) > Copy Feature > Reduce/Enlarge > Custom on the control panel.
  2. Enter the appropriate copy size using the numeric keypad.
  3. Press OK to save the selection.
  4. Press the (Stop/Clear) button to return to ready mode.
    When users make a reduced copy, black lines might appear at the bottom of the copy.
