Samsung Laser Printers - Set up an address book using SyncThru™ Web Services
This document provides information on how to create and manage addresses into categories on your printer's memory using the SyncThru™ Web Service, a web-based application that is available for Samsung printers.
Follow these steps to set up contacts in the Address book:
Supported printers
This document applies to the following printers:
  • Samsung MFP SL-K3250
  • Samsung MFP SL-K3300
  • Samsung MultiXpress Color MFP SL-X3220
  • Samsung MultiXpress Color MFP SL-X3280
  • Samsung MultiXpress MFP SL-K4250
  • Samsung MultiXpress MFP SL-K4300
  • Samsung MultiXpress MFP SL-K4350
  • Samsung Color MFP SL-X4220
  • Samsung Color MFP SL-X4250
  • Samsung Color MFP SL-X4300
Step five: Manage group addresses in the Address book
Login into the SyncThru™ Web Service website, and then follow these steps to manage group addresses:
  1. Create and save a group address.
    1. Click Address Book, and then select Group.
    2. Click Add Group, and then type a name of the group to be added in Group Name.
      To add individual addresses to the group address you created, select the Add individual(s) after this group is created check box.
      OR
      To add individual addresses later, click Group Details
    3. Click Apply.
    4. Select the check box of the addresses you want to add to Group Address Book from Individual Address Book.
    5. To add the selected addresses to the Group Address Book, click the arrow in the middle.
    6. Click Apply.
  2. Edit an address group.
    1. Click Address Book, and then select Group/ OR Groups.
    2. Select the check box of a group address you want to edit and then click Edit Group.
    3. Modify the group address information, and then click Apply.
      Click Undo to delete any information entered.
      Click Cancel to close the Edit window without saving any changes.
  3. Delete an address group (Optional)
    1. Click Address Book, and then select Group OR Groups.
    2. Select the check box of the groups you want to delete and then click Delete Group.
    3. When the confirmation window displays, click OK.
