Samsung Laser Printers - Using Special Print Features
Special print features include:
  • Printing multiple pages on one sheet of paper
  • Printing posters
  • Printing booklets
  • Printing on both sides of the paper
  • Change the size by percentage of the document
  • Fitting the document to a selected paper size
  • Using watermarks
  • Using overlay
The number of pages to print on a single sheet of paper can be selected. To print more than one page per sheet, the pages will be reduced in size and arranged in the order specified. Up to 16 pages on one sheet can be printed.
Figure : Page per sheet
  1. To change the print settings from the software application, access Printing Preferences. See Opening printing preferences.
  2. Click the Basic tab, select Multiple Pages Per Side in the Type drop-down list.
  3. Select Page Border to print a border around each page on the sheet.
  4. Select the number of pages required to print per sheet (2, 4, 6, 9, or 16) in the Pages Per Side drop-down list.
  5. Select the page order from the Page Order drop-down list, if necessary.
  6. Click the Paper tab, select the Original Size, Source, and Type.
  7. Click OK or Print until exiting the Print window.
Printing posters
This feature allows for printing a single-page document onto 4, 9, or 16 sheets of paper, for pasting the sheets together to form one poster-size document.
Figure : Poster
  2. Click the Basic tab, select Poster Printing in the Type drop-down list.
  3. Select the appropriate page layout.
  4. Select the Poster Overlap value. Specify Poster Overlap in millimeters or inches by selecting the radio button on the upper right of the Basic tab to make it easier to paste the sheets together.
    Figure : Poster sheets
  5. Click the Paper tab, select the Original Size, Source, and Type.
  6. Click OK or Print until exiting the Print window.
  7. Complete the poster by pasting the sheets together.
Printing booklets
This feature prints the document on both sides of the paper and arranges the pages so the paper can be folded in half after printing to produce a booklet.
Figure : Booklet
(For K4250, K4300, K4350, X4220, X4250, X4300 models only): To make a booklet, it is required to print on Letter, Legal, A4, JIS B5, Statement, Executive, A5, Ledger, or JIS B4 sized print paper.
  1. To change the print settings from the software application, access the Printing Preferences. See Opening printing preferences.
  2. Click the Basic tab, select Booklet Printing from the Type drop-down list.
  3. Click the Advanced button. Then select the appropriate option.
  4. Click the Paper tab, select the Original Size, Source, and Type.
    The Booklet Printing option is not available for all paper sizes. To find out the available paper size for this feature, select the available paper size in the Original Size option on the Paper tab. If an unavailable paper size is selected, the option can be automatically canceled. Select only available paper; without the or symbol.
  5. Click OK or Print until exiting the Print window.
Duplex; printing on both sides of a paper is available. Before printing, decide how the document is oriented.
(For K4250, K4300, K4350, X4220, X4250, X4300 models only): Only use this feature with Letter, Legal, Oficio, US Folio, A4, ISO B5, JIS B5, Statement, Executive, A5, 8K, 16K, Ledger, Tabloid Extra, or JIS B4 sized paper.
Do not print on both sides of special paper, such as labels, envelopes, or thick paper. It might cause a paper jam or damage the printer.
  2. Click the Basic tab.
  3. From the Double-Sided Printing section, select the appropriate binding option.
    1. Printer Default: When selecting this option, the feature is determined by the setting made on the control panel of the printer. This option is available only when using the PCL printer driver.
    2. None: Disables the feature.
    3. Long Edge: This option is the conventional layout used in bookbinding.
      Figure : Long edge
    4. Short Edge: This option is the conventional layout used in calendars.
      Figure : Short edge
    5. Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing. (For K4250, K4300, K4350, X4220, X4250, X4300 models only.)
Change the size of a document to appear larger or smaller on the printed page by typing in the appropriate percentage.
Figure : Image adjustment
  2. Click the Paper tab.
  3. Select actual paper size of the originals from the Original Size.
  4. Enter the scaling rate in the Percentage input box. It is also possible to use the up/down arrows to select the scaling rate.
    This feature is unavailable when selecting a size of paper from the Output Size.
  5. Select the Source and Type.
This printer feature allows scaling the print job to any selected paper size regardless of the document size. This option is useful when checking the fine details on a small document.
Figure : Fitted document
  4. Select the size of paper to be printed in the tray from the Output Size.
Using watermarks
The watermark option allows printing text over an existing document. For example, it is used when it is necessary to have large gray letters that read DRAFT or CONFIDENTIAL printed diagonally across the first page or all pages of a document.
Figure : Watermark
There are several predefined watermarks that come with the printer. They can be modified, or new ones can be added to the list.
  • Header: The selected text can be added to the top left, top center, or top right.
  • Footer: The selected text can be added to the bottom left, bottom center, or bottom right.
Using an existing watermark
  2. Click the Advanced tab, and select the desired watermark from the Watermark drop-down list.
    1. The selected watermark can be seen in the Triple Cassette Feeder image. (For K4250, K4300, K4350, X4220, X4250, X4300 models only.)
  3. Click OK or Print until exiting the Print window.
    1. For K4250, K4300, K4350, X4220, X4250, X4300 models only:
      1. Watermark Message: Allows users to enter the watermark the user wants to print.
      2. Image File: Allows users to load the watermark image the user wants to print.
      3. Watermark Name: Allows users to enter the watermark name for adding it to the watermark drop-down list.
      4. First Page Only: Prints watermark only on the first page. Not checked by default.
Creating a watermark
  2. From the Advanced tab, select Edit... from the Watermark drop-down list.
  3. Enter a text message in the Watermark Message box. Up to 256 characters can be entered. When the Draw On First Page Only box is checked, the watermark prints on the first page only.
  4. Select watermark options. The user can select the font name, style, size, and shade from the Font Attributes section, as well as set the angle of the watermark from the Watermark Alignment and Angle section.
  5. Click Add to add a new watermark to the Current Watermarks list.
  6. When finished with editing, click OK or Print until exiting the Print window.
To stop printing the watermark, select None from the Watermark drop-down list.
Editing a watermark
  3. Select the watermark to edit from the Current Watermarks list and change the watermark message and options.
  4. Select Update to save the changes.
Deleting a watermark
  3. Select the watermark to delete from the Current Watermarks list and click Delete.
  4. Click OK or Print until exiting the Print window.
Using overlay
This option is available only using the PCL printer driver.
What is an overlay?
An overlay is text and/or images stored on the computer hard drive (HDD) as a special file format that can be printed on any document. Overlays are often used to take the place of letterhead paper. Rather than using preprinted letterhead, users can create an overlay containing the same information that is currently on the letterhead. To print a letter with the company’s letterhead, users do not need to load preprinted letterhead paper in the printer just print the letterhead overlay on the document.
Figure : Overlay
Creating a new page overlay
To use a page overlay, users must create a new page overlay containing the logo or image.
  1. Create or open a document containing text or an image for use in a new page overlay. Position the items exactly as they are to appear when printed as an overlay.
  2. To save the document as an overlay, access Printing Preferences. See Opening printing preferences.
  3. Click the Advanced tab, and select Create from the Overlay drop-down list.
  4. In the Save As window, type a name up to eight characters in the File Name box. If necessary, select the destination path. The default is C:\Formover.
  5. Click Save.
  6. Click OK or Print until exiting the Print window. When a confirming message window appears, click Yes.
  7. The file is not printed. Instead, it is stored on the computer's hard disk drive.
    The overlay document size must be the same as the document printed with the overlay. Do not create an overlay with a watermark.
Using a page overlay
After an overlay has been created, it is ready to be printed with the document. To print an overlay with a document:
  1. Create or open the document to print.
  2. To change the print settings from the software application, access Printing Preferences. See Opening printing preferences.
  3. Click the Advanced tab.
  4. Select the Print Overlay from the Overlay drop-down list.
  5. If the overlay file does not appear in the Overlay File 1 or Overlay File 2 drop-down list, select Load from the Overlay List.
    1. Select the appropriate overlay file to be used. If the overlay file the user wants to use is in an external source, the file can be loaded accessing the Load window
    2. After selecting the file, click Open. The file appears in the Overlay List box and is available for printing. Select the overlay from the Overlay List box.
  6. If necessary, check Confirm Page Overlay When Printing box. If this box is checked, a message window appears each time submitting a document for printing, asking to confirm an overlay is to print on the document.
    1. If this box is not checked and an overlay has been selected, the overlay automatically prints with the document.
  7. Click OK or Print until exiting the Print window. The selected overlay prints on the document.
    The resolution of the overlay document must be the same as that of the document that will be printed with the overlay.
Deleting a page overlay
Users can delete page overlays that are no longer used.
  1. In the Printing Preferences window, click the Advanced tab.
  2. Select the Print Overlay from the Overlay drop-down list.
  3. Select the overlay to delete from the Overlay List box. If the overlay file does not appear in the Overlay List, select Load from the Overlay List. Select the overlay file to be deleted.
  4. Click Delete.
  5. When a confirming message window appears, click Yes.
