Samsung Xpress Color MFP SL-C480 - Setting the Paper Size and Type
After loading paper in the paper tray, set the paper size and type using the control panel buttons.
The paper setting in the printer and driver must match to print without a paper mismatch error.
  • To change the paper setting set in the printer from Samsung Easy Printer Manager program or SyncThru™ Web Service.
    • If the printer is connected to the local, set the printer’s setting from Samsung Easy Printer Manager > Advanced Setting > Device Settings, see Using Samsung Easy Printer Manager.
    • If the printer is connected to the network, set the printer’s setting from SyncThru™ Web Service > Settings tab > Printer Settings, see SyncThru™ Web Service.
  • It can be set using System Setup > Paper Setup > then select either the Paper Size or Paper Type button on the control panel.
  1. Select (Menu) on the control panel.
  2. Press System Setup > Paper Setup > Paper Size or Paper Type.
  3. Select the appropriate tray and the option required.
  4. Press OK to save the selection.
  5. Press (Stop/Clear) to return to ready mode.
To use special-sized paper, such as billing paper, select the Paper tab > Size > Edit... and set Custom Paper Size Settings in the Printing Preferences, see Opening printing preferences.
Using the output support
The surface of the output tray might become hot if when printing many pages at one. Make sure that not to touch the surface, and do not allow children near it.
The printed pages stack on the output support, and the output support will help the printed pages to align. The printer sends output to the output tray by default.
Figure : Output support
Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type, see Front view.
